Help with fuel pump/parts for tvs1900
I've searched but can't find a complete answer.
What's needed (fuel pump) to install a Roush TVS1900 on an '06 1500 5.3 non flex fuel?
I've read either a walbro 255 or aeromotive 340, but honestly I don't have a clue on what else is needed, like extra hoses, harness, etc.
Is there a kit that includes everything? Where can I order it?
The plan is to install a 3" pulley down the road so which pump is needed?
Thanks
Thanks
You should be fine with a Walbro GSS340 (255lph) pump, does the Roush setup come with injectors? I would avoid the Aeromotive pump with your fuel system as I was advised by a Very reputable shop that builds custom fuel systems that the Aeromotive flows to much fuel at the 58-60psi that the returnless systems run at idle. Basically your idle fuel pressure will get really high.
The Roush comes with a 3.3" pulley and in theory should get 8-9psi out of a 5.3. The plan is to pulley down to a 3" pulley and be done.
As for the boost a pump, how much hp can it handle working with the stock pump?
Oh and forgot to ask, is a new harness needed to run the Walbro?
my truck isn't flex fuel either, and was fine with a boost a pump and 60 lb motrons.
GM builds a ton of extra room into stock fuel pumps, for example my 502 ramjet crate motor is 510/580 in the paperwork the fuel pump they recommend was for obs 96-99 vortec 350's rated at 255hp from the factory, that pump has worked fine for 30k miles essentially doing double what it was designed for.
GM vehicles run at 4 bar in recent years (60 lbs roughly fuel pressure) injectors are rated at 3 bar (45ish) for uniformity.
I would call Kenne Bell (not sure how their customer service is), Lingenfelter or another reputable speed shop about how much the BAP will support on your pump. On their website, iirc, the single unit is good to 800hp, but obviously not every application is the same so I would talk to someone with experience with them.
Thanks
Thanks
Oyeah if you want to pulley down, Im pretty sure you have to get the snout of the supercharger turned down by a machine shop.
