Help with Gears, 4.10's not cutting it w/Turbo
Old 03-05-2011, 12:09 PM
kazfan30's Avatar
No...just vac brakes for now... So it seems that a gear swap would not benefit me...?
Old 03-05-2011, 03:45 PM
gavin2005's Avatar
do the hydroboost swap and get a 2 step.i just did it and my brakes are 10 times better.i went to the junkyard and got hydroboost pump,pedal and lines for 40 bucks.
Old 03-05-2011, 05:06 PM
Banned
Man im at 10psi at around 4k, so it seems to spool ok. My biggest question is that one would think traction would be horrible, but I really dont have too much trouble.. I hear guys breaking loose on 40 rolls, I just go lol with no spin at all. So am I low on power, or truck just hooks lol I dunno. Oh and I run 28.5 inch tires on 18 inch titans
hard to believe a 5000lb rig with turbo making 500rwhp can just blow the tires rolling into it at 40
Old 03-05-2011, 06:47 PM
denali_on_26's's Avatar
Location: Where our street cars are faster than your racecars..Mississippi
Does no one understand that a turbe needs a "load" to get its full potential?
Gears will make all the difference in the world.... Trust me ive been through it
Old 03-05-2011, 06:48 PM
Not sure if my crew cab weights 5000lbs with the 26's
Old 03-05-2011, 07:07 PM
9 Second Truck Club
tarinitup's Avatar
You should 4800 lbs breaking loose at 100.
Old 03-06-2011, 01:05 PM
kostelacd69's Avatar
If it makes you feel any better I cant hold my truck at the line very well either. The only way I can get it to hold is if when I'm done with my burn out I rev it in neutral a couple of times to help the booster get some vacuum in it. Even then it still wants to push through the line. I have 4.10's too. I just bought a used set of 3.42's that I'm going to try. I figure they will load the turbo harder when in 2nd and 3rd and maybe not push as hard. 2001 ecsb 402ci 4l80e gt4508r
Old 03-06-2011, 02:14 PM
When I come home from Iraq I can let you know how it works out for me lol. With 410's at 9-10 psi I ran 12.02. Let me finish tuning and do the gears and Ill let you know where I end up.
Old 03-07-2011, 09:12 AM
Banned
let me guess, you have a chinese nextang tire on the back with 26s?
put a drag radial on it or something, spinning aint winning, heck my 90hp toyota can spin the cheap runner tires.
Old 03-07-2011, 02:04 PM
Look here HATER... I said nothing about spinning...we are talking about weight... dumbass
Drag radial for 26's....lmao idiot
My other truck has plenty of drag radial 390/45-15 to be exact
Quick Reply: Help with Gears, 4.10's not cutting it w/Turbo
