Help! Need some advice on pcv and smoke at idle!
Old 10-17-2011, 08:02 PM
bad cutt's Avatar
where can i find a check valve, and stock pcv valve?
Old 10-18-2011, 02:05 PM
carbongmc's Avatar
McMaster-Carr
Part Number #7768K51
This is the one I used for my set up.
Old 10-18-2011, 03:45 PM
11 Second Truck Club
joeyc125's Avatar
You may still need a restrictor. If it stops smoking when you hook vacuum up to the crankcase, that may be because the vacuum is simply helping pull the oil through the drains better. Might not seem like much, but its the little things that sometimes trick you with this stuff. Also, I'm sure its not fun with hot pipes, but you might want to try a compression check all around with the engine warm. Even getting it hot, then let it sit awhile, the pipes will cool a little faster then the engine, I would like to see #7 a little closer to the others, but it would be worth looking into. Got any pics of this truck? Sounds like a neat setup.
Old 10-22-2011, 02:10 AM
TT2005CREW's Avatar
Here are a few pics of my truck. I guess I should post these in the new member forum since I never have really introduced myself
Old 10-22-2011, 03:14 AM
99ta's Avatar
Off topic, do you have any pics of how you turned the overflow tank?
Old 10-22-2011, 10:43 AM
joeyc125's Avatar
Thats a really clean setup man! I like it!
drummer0415
11
10-24-2015 08:16 PM
Chevy305
09-28-2015 09:21 PM
01silvy
09-26-2015 10:20 PM
Cha_Feel_
09-23-2015 09:06 PM
Go5.3tt06
09-14-2015 02:11 PM
Quick Reply: Help! Need some advice on pcv and smoke at idle!
