Help! Radix Problem
Old 01-31-2008, 11:16 AM
  #91
laynlow77's Avatar
Originally Posted by 2005SSR6Speed
You may need to space the idlers out that have the shoulders on them. Look at the alignment of the belt and make sure that the belt is riding in the middle of the idlers. If the belt touches the shoulders on the idlers it will squeak.
even when i put the metco pulleys on it does the same thing. with these they ride in the center, but still arent the same side by side. if that makes sense.
Old 01-31-2008, 11:35 AM
  #92
FormerVendor
leftcoast32's Avatar
Do you know what length belt you are using right now? You may want to try the Dayco PolyCog belt the same length as I have had huge success with them. If you have the length I can cross reference it and give you the polycog number. Are you still using a 6 groove?
Old 01-31-2008, 11:41 AM
  #93
laynlow77's Avatar
its still the standard six groove. ill go get the lengths for you right now.
Old 01-31-2008, 11:46 AM
  #94
FormerVendor
Look at the last 4 numbers on the belt. How tight is the belt, is the tension real tight, in the middle or loose?
Old 01-31-2008, 11:59 AM
  #95
laynlow77's Avatar
the belt is pretty snug. ive tried the longer one (napa) with the idler adj. all the way up or down and it does the same thing. and the shorter one (gates) as well.
napa - pn 25-061140
gates -pn k-061120
Old 01-31-2008, 12:14 PM
  #96
FormerVendor
napa - pn 25-061140 - 114"
gates -pn k-061120 - 112"
5061115 - 111.5"
5061120 - 112"
5061130 - 113"
Make sure to go and tell them you need the performance version of the belt as they have an economy version too. PepBoys has them and can do a special order if they are not a stocked size, they also have a lifetime warranty. I tell my customers to get 2 and change them out every 6 months on a daily driver.
Old 01-31-2008, 12:23 PM
  #97
James B.'s Avatar
It's not belt tension causing this. It has to be the offset of the supercharger pulley and/or the axis of the supercharger and/or the idlers pulleys. It is unlikey the supercharger is off-axis since it has to bolt square to the intake and the heads, but the pulley could be set back too far. My focus would be on the driverside of the two idler pulleys and checking the axis of that. Maybe it's not square, looks like it could be pointing up. Check that everything squares up.
Old 01-31-2008, 12:31 PM
  #98
FormerVendor
The gates belts will start to squeak as soo as they have a glaze on them. When he said he was getting alot of belt dust then the squeak I would look at the belt and slip issues.
Old 01-31-2008, 12:48 PM
  #99
laynlow77's Avatar
5061115 - 111.5"
5061120 - 112"
5061130 - 113"
what size belt would you recommend. do you happen to know what comes stock with a 3.3? should be a stock 6.0 kit
Old 01-31-2008, 01:08 PM
  #100
FormerVendor
Once you change the pulley's then you should just get the tightest belt you can comfortably get on. If you can get the 112" on easy I would put the 111.5" on. If they have them in stock try a few different sizes in the parking lot, I would guess the 111.5" will work for yours. The last 4 numbers in the part number are the length.
Quick Reply: Help! Radix Problem
