Help! Radix Problem
#101
where should the tensioner be at, somewhere in the center right? tried to get another 114 and it still made noise. i really believe that the idler bracket is bent... it goes from the tensioner to the idler, up to the supercharger, and then down to the other idler. the belt rides 1/4 inch or so further back on the drivers one. my buddies doesnt do this.... any clue?
#102
#103
thats what i thought as well. what adjustment could be made though. the supercharger is obviously not moving, and the alternator is on the main accy bracket that is hard bolted in. ive taken it off to make sure that its not "cocked" or hitting anything. (like the spot they tell you to grind off). im baffled.... i need to figure out the stock belt size and go from there, but i know that the idlers just arent right.
#104
#105
If the only change has been with the idlers then I would go back to the stock idlers and see if the issue is still there. I have tested alot of idlers and had issues with a wobble that can only be seen under a load. If the pull of the belt is causing an angle on the idler then the only way to fix it is to go back to an idler that doesn't. Take the belt off and check the idlers once they are warm and see if they move on the bearings at all.
ive tried the stock idlers as well before, no change. ill try it again tomorrow with a new belt and see what happens.... mind if i give ya a call tomorrow? it might be easier than exchanging messages.
#106
Give me a call anytime. Joe (760) 522-8669
#109
ive taken it off and nothing seems wrong with it. still has plenty of tension. also, i stole the "new" style idler bracket from my buddy and it didnt fix anything, so i guess that means my "old" style old one isnt bent.
#110
what a rush!
Things I would look for you have already looked at.
a while back, there was a guy that checked the true-ness of the actual idler bracket and found it was not true, had it machined, and fixed his problem that way.
does the tensioner stay true under tension?
