Help! Radix Problem
Old 02-03-2008, 02:34 PM
  #111
FormerVendor
leftcoast32's Avatar
Originally Posted by laynlow77
ive taken it off and nothing seems wrong with it. still has plenty of tension. also, i stole the "new" style idler bracket from my buddy and it didnt fix anything, so i guess that means my "old" style old one isnt bent.
If you were closer I would say to stop by the house on a weekend and we can troubleshoot the problem.
Old 02-03-2008, 06:34 PM
  #112
12SEC SS's Avatar
My belt looked similar to yours. For me, it was a two-part fix. First, alternator looked like it was sitting too far back, I loosened the bolts and put a shim under each side between alternator and bracket, to bring the alternator out just a little. Second, it was smooth pulley on my tensioner that I got from Magnacharger, turns out i needed a ribbed pulley on it. Once I did that, problem dissapeared completely.
Old 02-07-2008, 08:08 PM
  #113
laynlow77's Avatar
update!!
got a new tensioner and idler bracket...didnt change a thing......
i flipped the supercharger pulley to push it further out, and it seems to have worked. if anything its just a little bit too far out now.
are your guys' pulleys with the numbering on the inside or outside?
can i get some more pics from you?
Old 02-07-2008, 08:10 PM
  #114
2nd fastest 5.3 ECSB
trever1t's Avatar
numbers out for me.
Old 02-07-2008, 08:26 PM
  #115
laynlow77's Avatar
Originally Posted by trever1t
numbers out for me.
that is what i always thought it was too! wonder why this fixed it?
Old 02-07-2008, 10:30 PM
  #116
12SEC SS's Avatar
After I swapped pulley to a 2.9" one that I bought from Magnacharger, the belt sat waay too far in. I ended up throwing like almost a 1/4" spacer behind it. I called magnacharger about it, they are clueless, and so am I. Pulley is on letters out, seems to run fine with my spacer in there and not throwing any belts or any foreign noises. Puller was used to remove the stock pulley, and impact gun to tighten the nut after new pulley was firmly on the shaft.
Old 02-07-2008, 10:32 PM
  #117
blownerator
BlownChevy's Avatar
sounds to me like someone sent the wrong pulley. Do you have the original paperwork? If so PM me the invoice number.
Old 02-08-2008, 01:44 PM
  #118
12SEC SS's Avatar
Unfortunately this was a month or two ago, and i dont have the paperwork...I did however call right after I tried to put it on, and iirc I spoke to David who re-assured me they send me the right pulley. I even spoke to their tech support and they were clueless as well. They said like maybe the seal got pushed back in or something, but i think i would have a lot of nose by now or something would have broke, but its running fine...
Old 02-08-2008, 01:58 PM
  #119
blownerator
BlownChevy's Avatar
pm me your full name. I want to make SURE its the right one.
madmann26
04-29-2020 09:17 AM
dsbodley
11-14-2015 09:46 PM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
02AWDAWSDenali
10-01-2015 05:08 PM
sTNT971
09-26-2015 06:27 AM
Quick Reply: Help! Radix Problem
