Help! Radix Problem
Old 01-02-2008, 09:24 PM
blownerator
BlownChevy's Avatar
I would suggest checking the crank pulley, and if you have not pinned it....DO IT.
Old 01-02-2008, 09:26 PM
laynlow77's Avatar
in the first picture you can see how the belt actually comes down after the blower (driver side) and it is slightly hanging off of the pulley.
Originally Posted by XLR8NSS
When my crank bolt backed out and the crank was walking it threw my belt out of alignment but, it was out equally on all pulleys. It's worth a look though. If you haven't pinned the crank you REALLY should do it.
its been on my list, but never got around to it... i guess now its at the top.
Originally Posted by moregrip
I thought there was a funky looking stock spacer on there, maybe I don't remember right
there is a three piece assembly that is all held together to make that one pulley, is that what youre talking about?
Originally Posted by BlownChevy
Honestly I do not see anything out of the ordinary. Where do you see the issue? The belt will walk back and forth on the idlers under different loads, so un-even wear is common.
just as soon as it starts the belt is uneven coming up and down the blower. it never used to be like this, and ive check my buddys setup and its not like this either. ive been getting alot of belt dust and belt whine lately. the car is undriveable at this point.
Old 01-02-2008, 09:30 PM
what a rush!
moregrip's Avatar
yes
Old 01-02-2008, 09:32 PM
blownerator
BlownChevy's Avatar
Check your idler bearings....Check your balancer.
Old 01-02-2008, 09:36 PM
laynlow77's Avatar
yes
even when i put the metco pulleys on it does the same thing. the balancer will be checked tomorrow, what should it be torqued to again?
Old 01-02-2008, 09:37 PM
496chevy's Avatar
i know nothing about these things, but did the charger's pulley come un-assembled?
clint
and are the 2 idlers in line with each other (looking from the top - down)? in the pic its hard to see..
Old 01-02-2008, 09:39 PM
laynlow77's Avatar
clint
i checked that as well, it is all the way down on the snout, i took it off and checked. i also changed it with a 3.7 pulley i had and it looked the same.
Old 01-02-2008, 09:44 PM
what a rush!
moregrip's Avatar
you know, the more I look at those pics the more I think your mis alignment is greater than it should be. When you took those pics had the engine been run? or was that right after you put the belt back on?
Old 01-02-2008, 09:50 PM
laynlow77's Avatar
it was after the engine was ran, as soon as i fire it up it goes right back to this spot. ive tried taking the belt off and readjusting but it just goes right back.
Old 01-02-2008, 09:51 PM
496chevy's Avatar
is the pulley a one way deal or is it reversable for the "fool proof install"... again, i only wish i had your problem
clint
Quick Reply: Help! Radix Problem
