Help! Radix Problem
#74
what a rush!
Actually it was the first set of pulley's (from another company) that walked off the bearing. I couldnt make it around the block. Then the Metco's didnt walk off the bearings (snap rings) but had a high speed wobble and wouldnt survive above 5000 rpm's under a load. Every part has a limit, the TBSS even ripped a water pump pulley off too.
#77
#78
blownerator
Damn Blown you just wont give up. I guess your going to tell me giving a girl bigger **** wont make the distance between them smaller? Its math. 90+10=100 => 100>90 If your adding bigger pulleys then the distance between them is smaller. Therefore your pinching the belt more between the pulleys wich equals more belt wrap around the snout. Sliding them up or down has nothing to do with the distance between them. that never changes EXCEPT with bigger pulleys.
Unless you place an idler up closer to the blower drive pulley(see pic below), or get a 400MM idler pulley down in the stock location the gains are negligible at best. But hey, its your 100 bucks, spend it how you would like. I am only offering up what I have learned in my experiance and testing.
BTW I love big boobies I read all of your posts after the rant, I am not mad either.....just trying to save a few bucks for some people.
Before
After
