help, truck is shooting flames
Old 08-02-2011, 02:05 AM
doesn't know what quit means
lablackbeast's Avatar
Default help, truck is shooting flames
Well guys I been having this problem ever since I tuned it completely on the dyno with flaco, well the truck gets up to 120 plus and when I let off it starts shooting flames from the exhaust, don't know why is it doing it but at first we thought it was the spark plugs that were gaped a .20-.25 so I put them to .30 and still kept doing the same, does anybody have a idea of what it could be.??
Old 08-02-2011, 02:11 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
What kind of fuel are you using, and what's your AFR at WOT?
Old 08-02-2011, 02:20 AM
93 octane and I am seeing low 12s high 11s
Old 08-02-2011, 02:22 AM
I have a gauge for that
Atomic's Avatar
Do you have DFCO enabled in the tune?
Old 08-02-2011, 02:25 AM
What is that.?
Old 08-02-2011, 02:50 AM
Atomic's Avatar
It turns off the fuel injectors when a certain set of parameters are met (speed, map, throttle). If its not turned off in your case you may pass unburnt fuel through the engine and then it ignites in the exhaust from the heat. Kind of a long shot though...
Old 08-02-2011, 07:55 AM
dlt76028's Avatar
^^^ not a bad start
Old 08-02-2011, 08:16 AM
DBRODS's Avatar
Mine was doing that too when we were tuning in the E85 and N20. Needless to say it was pretty fat, after leaning it out it went away..
Old 08-02-2011, 08:47 AM
Gadgetized's Avatar
What injectors are you running? What is your AFR in the low kPa area? Bigger injectors can sometimes run real rich in lower kPa areas. My 60lb injectors were seeing 10, 9, and even 8:1 AFR down low. I had to adjust the base pulse width to correct this. Unburned fuel will do exactly what you are saying (just as Atomic said).
Old 08-02-2011, 08:53 AM
mhotrodscooter's Avatar
What headers or you running? When I was running the obx with 2.5 collectors. They would turn cherry red on the dyno & shoot fire out the cutouts after 3 dyno pulls back to back.
So if your exhaust is flowing good you could be getting a build up of exhaust gases.
Quick Reply: help, truck is shooting flames
