How to determine turbo size...tt setup
Originally Posted by wondertruck
thanks for the info Rick, great stuff. I'm running solid roller and a victor jr. manifold.
RIck
Banned
vic. jr= total loss of low end torque over stock manifold (on motor) below ~3700-4000rpm. Above that it does feel like it pulls a ton harder. I need to have another set of heads done with the Vic. in mind. The heads I have now are just a set of stage 1.5 TSP heads that were designed for a stock manifold.
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
R
LS1TECH Sponsor
I'm running a 370, ~4250# range, not a track only thing however it shall run like it is. A single 76 would probably be nice on it, I want to stay with the larger frame so I can upgrade later if I want. A friend nas an S88 that has been modded to 91mm, thought about building the kit using that as a mockup, and then going with the same frame 76mm. I would like to see ~750rwhp with a mild setup not pushing to hard.
Our S88's are no joke, and the S91's are going to be plain sick.
When choosing a proper turbo, if you want it done correctly, you will need more then just the consumption chart and compressor map.
shupe
08-05-2015 06:45 PM
