How hard would it be to boost control a centri blower
Old 11-17-2008, 10:02 PM
  #21
rockerjoe2008's Avatar
Yea, and the restrictor plate causes heat issues and stress on the blower.
Old 11-18-2008, 03:23 AM
  #22
Adkoonerstrator
XLR8NSS's Avatar
Well, one of the guys that actually works at Procharger posted a while back on Tech about it. He said it works well IIRC.
I heard one time that it causes oil to be drawn past the seals because of high vacuum at the inlet but, he said that is not a problem. If I can find the post I'll put a link up.
What type of stress? It seems no matter what way you go the blower is still gonna be spinning the same rpms either way.
The whole purpose of the restrictor is so you can put a smaller pulley on and get more air in the lower rpms while restricting flow up top to a reasonable level. I don't think it is used to pulley up to 30psi and restrict to 15 but, more like 4-5psi difference most of the time.
I'll look for that post later today.
Old 11-18-2008, 02:01 PM
  #23
Adkoonerstrator
XLR8NSS's Avatar
Ok, here is the post. I might have remembered things slightly off from what they are in the post but, it's a good read. Pay close attention to andereck. He did/does work for procharger, not sure anymore if he is still there.
https://ls1tech.com/forums/forced-in...tor+procharger
Old 11-18-2008, 02:55 PM
  #24
Baltimore Whore
Mangled03gmc's Avatar
John, thanks I am gona read that now, ??? wheres my 12 sec title at damn it hahahaha
John
Old 11-18-2008, 09:45 PM
  #25
By stress I mean the blower has to work harder to draw the same amount of air. Like the difference between sucking soda through a straw and sucking milkshake through a straw. You would have to work a lot harder to suck milkshake through a straw as fast as you suck soda. Maybe this illustration doesn't really apply to the restrictor plate but it to me it seems like the same principle. Maybe this illustration just sucks
I am still learning and trying to figure this stuff out just like you guys.
Old 11-18-2008, 10:05 PM
  #26
Adkoonerstrator
XLR8NSS's Avatar
I think what the guy is saying in this post is that drive losses are gonna be higher if you take the air in, compress it, then dump it over just not taking it in(restrictor). He is the procharger guy I was talking about.
https://ls1tech.com/forums/5940106-post12.html
Old 11-18-2008, 10:27 PM
  #27
MFIC's Avatar
Also here is the post on the corvette superchaged w/ boost controller https://ls1tech.com/forums/forced-in...ntrollers.html
Old 11-20-2008, 09:12 PM
  #28
11 Second Truck Club
Superado's Avatar
Mark (andereck) is no longer w/ ATI ProCharger...
Old 11-20-2008, 09:32 PM
  #29
zippy's Avatar
I have been waiting for someone to post that guy from LS1Tech. Every time I read this I was going to look for it, then got busy reading other posts and forgot about it. With a Procharger you get the advantage of quick boost out of the hole, just not alot which allows you to run a bit smaller tire and pick up the number on the high end. With a big enough cam and head package you can also keep the boost more consistant with a Procharger. If you are getting too much boost before the shift point when you pulley down for more boost at the low end, just add more cam. Seriously though, the loss of parasitic power from turning the blower faster than you need is just a waste of power. Unless you're hitting over 15psi or so on pump gas, just use the extra boost. Tune for it.
Old 11-20-2008, 09:42 PM
  #30
Superado's Avatar
from one of the articles linked above:
http://www.musclemustangfastfords.co...all/index.html
GXPJAY
02-13-2022 08:15 AM
greedygenius
09-03-2015 06:51 AM
Razor
08-16-2015 11:39 PM
lxcoupe
07-15-2015 10:03 PM
Quick Reply: How hard would it be to boost control a centri blower
