How many have gone from radix to turbo?
How do I change this text
I have a radix and my son has a turbo. I won't be switching any time soon. I'm sure we have similar power numbers, but I know I can run away and hide before he gets more than a few psi of boost. My power is availabe with a tap of the right foot. No lag, no gradual buildup, it's just there. I don't need or want any more than 500 at the wheels. Over that and you get into beefing up everything on the drivetrain plus higher stall converters. I'm running a stock converter....turbos can't do that and hope to keep up. When you get into power levels over 500 and race only apps, you get into a whole 'nother arguement.
It really boils down to what you want out of your truck and how you want that power to "feel"
I have done both. First I had the Radix and it was extremely reliable. Made good power and the tq curve was crazy. I was hitting 1.8 60' times. Problem was it was too small for the 6.0 with a 3.0 pully I was getting 8# when it wasnt slipping the belt. It also made a crap load of heat and would fall off on the top end.
I swapped over to turbo, and with a gt72 at 11# was hitting 2.0-2.1 60' but was alot faster. That was with an extremely rich tune that was hurting power. 10:1 AFR. The power delivery is completely different. Both setups have their pros and cons. The turbo is more maintenance, and has had more problems than the Radix did, but the turbo has alot more potential.
