How many have gone from radix to turbo?
Old 01-13-2009, 09:32 PM
How do I change this text
Wilde Racing's Avatar
Originally Posted by old motorhead
I have a radix and my son has a turbo. I won't be switching any time soon. I'm sure we have similar power numbers, but I know I can run away and hide before he gets more than a few psi of boost. My power is availabe with a tap of the right foot. No lag, no gradual buildup, it's just there. I don't need or want any more than 500 at the wheels. Over that and you get into beefing up everything on the drivetrain plus higher stall converters. I'm running a stock converter....turbos can't do that and hope to keep up. When you get into power levels over 500 and race only apps, you get into a whole 'nother arguement.
Very nicely put.
It really boils down to what you want out of your truck and how you want that power to "feel"
Old 01-13-2009, 10:02 PM
blownerator
BlownChevy's Avatar
If you are ever in Cali I will take you for a real ride Dont let the darkside fool you, there is plenty of power to be made with The Magna Charger if you know what you are doing.
Old 01-13-2009, 11:13 PM
thunderwagen's Avatar
I have done both. First I had the Radix and it was extremely reliable. Made good power and the tq curve was crazy. I was hitting 1.8 60' times. Problem was it was too small for the 6.0 with a 3.0 pully I was getting 8# when it wasnt slipping the belt. It also made a crap load of heat and would fall off on the top end.
I swapped over to turbo, and with a gt72 at 11# was hitting 2.0-2.1 60' but was alot faster. That was with an extremely rich tune that was hurting power. 10:1 AFR. The power delivery is completely different. Both setups have their pros and cons. The turbo is more maintenance, and has had more problems than the Radix did, but the turbo has alot more potential.
Old 01-13-2009, 11:17 PM
blownerator
BlownChevy's Avatar
Signature material right there......
However you forgot: but the turbo had alot more potential, until the TVS came along.
Old 01-13-2009, 11:27 PM
TouchOfEvil04's Avatar
only people who wanna go fast......
Old 01-13-2009, 11:31 PM
what a rush!
moregrip's Avatar
interesting thread
Old 01-13-2009, 11:35 PM
chevrolade's Avatar
Well see how this thing runs on 9-10lbs
Old 01-13-2009, 11:37 PM
EVILGMC's Avatar
and soon see what a TVS with 9-10psi does on a 370....
Old 01-13-2009, 11:45 PM
old motorhead's Avatar
My truck on 9.5psi is just flat nasty. Stomp the go pedal at anything under 40mph results in instant tire smoke. I'm sure just about any turbo truck will do the same........it just may take a little longer.
Old 01-13-2009, 11:46 PM
chevrolade's Avatar
Did they make the tvs for 08'4.8?or only for 6.0 6.2?that front inlet(black)powdercoat looks sick!!
Quick Reply: How many have gone from radix to turbo?
