How much belt slip in reality....
I have a HD tensioner and set my belt length based on keeping my tensioner in the middle of its travel range. One advantage my setup has is that I have an adjustable idler that I can move and compensate for belt sizes and pulley changes within reason. My belt does not stretch a whole lot as its a 8 rib HD Belt.
I ended up stepping up to an 8 groove system and placing another tensioner near the snout to increase belt wrap on the supercharger pulley. It worked great and I got no belt slip. I will actually be selling the setup real soon. 2.6 supercharger pulley, 3 extra wide idlers, snout support, alt pulley, pwr steering pulley, 10% OD crank pulley, and the very low mile green gates belt. I just need to get some stuff together and post it up.
Find the longest distance between pulleys. You should not be able to twist the belt more than 45* by hand. If you cant twist it at all, its too tight. If you can twist it past 45*, its too loose
I reached the limit of the 6-rib belt at 14psi with a 3.25" pulley on my KB 2.8L even with relocated and larger idlers for ~290* of belt wrap. Boost graph looked like a staircase. Boost would start at 14 and drop to 9 by the shift point then jump back to 14 then down to 9 for every gear. Went to a 3.5" 8-rib with overdrive crank and HD tensioner and now see a steady 15# across the rpm range. KB recommends an 8-rib setup on their units for anything over 15psi which I found to be accurate.
I think belt routing and hardware setup are large factors in how well a supercharger will work without slip.
BROKE-aSS-BLAZER
10-13-2017 04:50 PM
Vortec350ss
01-12-2016 11:36 PM
advantage, belt, changed, combination, d1sc, forum, gates, hd, max, procharger, prochargerbeltslippage, pulley, pulleys, slip, slipping
