How much better at 11.5 vs, 10.3-5:1
I finally got to start logging after fuel system upgrade. I must have kept adding fuel before I had an adequate fuel supply. It must look liked a diesel when I put my good foot forward. I remember this subject was recently covered but I can't find it searching. I just am wondering what to expect.
My Magnafuel 4301 is now fed from a through-tank fitting with -12 hose. After the pre-filter and out of the pump, -10 line goes through a check valve into a tee fitting. Out to the fine filter after which the -10 line splits into two -8s that go to the fuel rails, stock return. This pump only runs above 1 psi boost. Into the other leg of the tee fitting is another check valve, fed by the stock in-tank pump. I don't want a fuel system that is only good enough, and this setup ought to take care of possible future mods.
