How Much Boost 'or' Max On 5.3l. !!!!!!!!
I HAVE A 2006 5.3L. STOCK BOTTOM END ,WITH 10K MILES ON IT I HAVE A CAM already befor the turbo 222/224 566/568 LIFT IN IT WITH 112LSA for right now till i get a custom turbo cam. WITH 3,000 PERFORMA BUILT TRANS. STALL AND IM INSTALLING A MASTER POWER T70 TURBO WITH
.68 A/R IN THE HOT SIDE. custom front mount
AND ALSO ORDER A SNOW PERFORMANCE STAGE 1 KIT (METH./WATER) with boost control
WITH 3'' INTERCOOLR 12 X 25 X 3'' COOLER SO HOW MUCH BOOST CAN I RUN WITH ALL THESE STUFF -MAX BOOST. I WAS THINKING 10PSI TO 12PSI BUT FOR RIGHT NOW ONLY 7 OR 8 POUNDS OF BOOST BUT I WANT 10 -12 PSI.
custom turbo tune with 255walbro fuel pump
OHH AND ALSO WITH 65. POUND INJECTORS AND WILL THIS MUCH WORK WITH IT AND WILL I MAKE CLOSE TO 500rwhPOWER WITH ALL THIS STUFF,
THANK YOU VERY MUCH FOR YOUR HELP
You may want to consider a fuel pump upgrade and some NGK TR6 plugs as well.
I am not a cam guy but that cam does not look right to me. Check out Vinci Performance ---------> Sponsor or Lingenfelter for an idea of where to begin for low end torque and/or turbo cam specs.
You need guages....WBO2-AFR; Fuel pressure; Boost.
You also need a boost control if you are going to be able to change it (boost that is
You will need traction!
Don't forget tuning.....you just didn't mention it so I will!
Looks like the beginning of a great build and you should be able to obtain 500 rwhp without any problem
Good luck and I know you will have a lot of fun with it.![Chug! Chug! Chug!](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_chug.gif)
![Secret2](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/secret.gif)
![Nod](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_nod.gif)
High on diesel fumes
That cam is probably a little big for a turbo on a 5.3. I'm running a 220/222 on a 113 or 114 LSA in my 408 and I wouldn't go any bigger. Yours has no overlap though, so it won't be too bad. Just might take a little bit to spool up. I'm sure you could spool quicker with a little bit smaller cam.
I think you can make more than 500rwhp with that setup. kbracing96 made 505/535 with his 4.8 with that same turbo and a 210/218 on 116 LSA cam at 12 psi.
So You Have The Comp Cams 222/224 And 566/568 Lift Cam With 112 Lsa With No Problem So I Can Run This Cam With It And How Dose It Idle's Bro With The Turbo It Feels Good Or What ??????????????????????????????????
No problems so far.
I am still working on some things and tuning, but it seems that my wastegate decided to take
![turd](https://www.performancetrucks.net/forums/images/smilies2/turd.gif)
Once I have some more real day to day driving and a couple of passes at the track, I will let you know.
I am in the same boat as you, I am trying this cam and will probably swap it out in the future and see how different a turbo cam feels. Or maybe a Z06 cam.
