How much boost shuold I have?
Car just came back from the dyno and the numbers seemed a bit low
Stock LQ4
LS6 cam
M122
2.6" SC pulley
7.8 crank pulley
10 rib drive, no slip
Only 6# of boost? 405/430
If you've got a M122, any brand, what pulley do you have and how much boost did you get from your 6.0?
Stock LQ4
LS6 cam
M122
2.6" SC pulley
7.8 crank pulley
That does seem very low. I would think you should be above 10+ with a good set of ported heads, and good flowing exhaust. I wouldn't be surprised if you hit 13.
Are you sure the bypass valve is fully closing? What style supercharger do you have? If it has a shaft, maybe the gears on the back got switched around (not sure about this, just a thought).
Not a jackshaft setup
![](http://i150.photobucket.com/albums/s98/Pocket_004/DSC02607.jpg)
1.75" LTs into a 4" single exhaust, no restriction there
I was estimating 13-15psi for the build, so when the tuner said all he got was 6, I was surprised. Thanks for the confirm, Ill pressurize the system and hunt for leaks
Should be right at 16lbs...
Bypass valve works properly. Its located under the inlet. I can manually close it and idle will become a surge
Tuner said power was right in line with the boost level which I agree with, but the boost level for pulley and blower displacement seems extremely low
