how much boost stock ls2?
I bought a complete trailblazer ss ls2 for dirt cheap and should have it running in my 03 rcsb silverado this weekend, the plan is to do a single turbo on it in the next month or two... how much boost are people running with these ls2's and what kind of power can the stock bottom end hold up to?
im new to the turbo thing, the plan is to try to run e85. if i run e85 which is a higher octane fuel will i be able to run more boost even with the 11:1 compression? if i wanted to change the heads which ones would you run the 317s?
