How much horsepower can a P1 support?
Do a search on corvetteforums in the C5 classifieds. They pop up there all the time.
For example...
WTB ls6 cam - Corvette Forum
Post #6
Rick
For example...
Post #6
Rick
Baltimore Whore
Just be sure to go over that cam with a fine tooth comb.. Check for anything that you can feel on the lobes.. I would also consider polishing the lobes again, just to clean them up..
Dammit. The guy just emailed me telling me it's a 2001 z06 cam. I wish he would have told me before I sent the payment. ![Sad](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_sad.gif)
Cam Specifications:
2001 LS6 cam
207/217 int/exh @ 0.05" duration
0.525" / 0.525" int/exh lift
116 LSA
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
What Procharger recommends:
Lobe separation: 112 to 116 degrees Split pattern: Exhaust duration and lift approximately 10 degrees and .010, respectively, greater than intake. Install cam straight up. Contact a cam manufacturer for lifts and durations that best suit your application.
What do you guys think? Should I still run it? Or put it on eBay or something?
Cam Specifications:
2001 LS6 cam
116 LSA
2002+ LS6 cam
117 LSA
