How much timing are you running on pump gas?
Old 01-28-2011 | 02:06 PM
  #21
foose04's Avatar
I'm surprised it wasn't breaking up in the 9's. Good numbers though, mustang dyno's are no joke!
Old 01-28-2011 | 03:57 PM
  #22
tarinitup's Avatar
9 Second Truck Club
Why Did you accept such a rich tune. At minimum get the bitch in the high 10s.
Old 01-28-2011 | 04:08 PM
  #23
tiffo60's Avatar
going that rich is just as bad as going lean....
Old 01-28-2011 | 06:03 PM
  #24
black00chev's Avatar
Slowest turbo build ever!
also curious how many #s your at to get those numbers on that MP70 with the 1.00
Old 02-01-2011 | 03:42 AM
  #25
02'Z71ONDUBZ''s Avatar
It was around 10 or 11 lbs. We couldnt get the boost any lower with the gate spring I had. Tried to lean it out a little and power fell. I didnt want to make a ton of pulls on the stock tranny, and havent made a wot pull since the dyno, thats why I wasnt as concerned. When I get a tranny in and a small enough spring to run my mbc then I'm gonna worry about dialing the tune in up top. The truck has alot left in it thats for sure.
Old 02-02-2011 | 11:48 AM
  #26
NicD's Avatar
9 Second Club
91 oct here sucks, at 7 psi on an LQ9 and the most I can really do is 15 degrees up top and about 12 at peak torque.
Old 02-02-2011 | 12:47 PM
  #27
smokeshow's Avatar
Mod with training wheels
Do you have the dyno graph? Looks like torque must have been falling off pretty hard up top. 490 isn't a bad number for torque at all, though. I run 16 degrees with meth on 10-11psi, running rich in the low-mid 10s. It's a work in progress.
Old 02-03-2011 | 01:16 AM
  #28
Here ya go
Old 02-03-2011 | 02:26 AM
  #29
1SlowHoe's Avatar
Destroyer of Transmissions
I can't make heads or tails of that dyno graph..
EDIT:
Ok, I studied a little harder...
That AFR is retarded. It comes in at 11.4 and just nose dives throughout the pull. It should be at 11.4 the whole time. It shows you at 9.4 at the top of your pull. There is probably enough raw fuel in your exhaust to start a fire in your tail pipe, fast and the furious style.
I've also never seen a dyno hp and tq cross at such a low rpm. In fact I thought it was always supposed to be at the 5,250rpm mark.
I don't understand why when you pulled fuel to lean it out you lost power. I'd think as fat as that thing is you'd pick up a ton of power going from low 9's to low 11's AFR.
Get that tranny in and get it back on the dyno for some tweaking. I'd almost be afraid of washing the cylinders with all that fuel. I know you said you haven't gone WOT since the dyno, just sayin...
Old 02-03-2011 | 12:43 PM
  #30
smokeshow's Avatar
Looks like theres more in it if you lean it out a bit...
