how much will the 6.0 handle?
hi guys im gettin the truck back next week with a 6.0 in it and they built the tranny while the motor was out. so im gettin a 6.0 with a built to the max 4L60. the 5.3 had a lowerend knock that i didnt like so i pulled it b4 it got bad. so if anyone needs any parts off a 5.3 let me know. but what i was wondering is what will the 6.0 handle? how much boost? and what kind of hp should i have out of this package with the turbo? they were going to put a cam in it right away but the tech at sts said that the cam in the 6.0 is perfect with for the turbo so they didnt touch that and other than alot of tuning it should go really well. but please give me your thoughts? thanks
Mitch
Mitch
Formerly Low_LQ4 - 6/6/10
Yep you should get a tranny swap before you run any boost.
6.0 can handle alot of hp IMO you should get some ARP rodbolts, your tranny will give up when you get to high hp soo you should think about that. I went through 3 4L60E and the same BS happens everytime.
Tin Foil Hat Wearin' Fool
haha do you know how many "built to the max" 60e's weve seen go under
With 35" tires, a 6.0 and boost your trans isnt going to last long at all I dont care how well it is built. You either need to back down your power goals or you need to swap to an 80e.
