that huge heat exchanger from frozen boost
Old 07-15-2010 | 03:44 PM
  #41
Atomic's Avatar
I have a gauge for that
As trick pointed out, I think the real issue is the intercooler size, not the heat exchanger.
Old 07-15-2010 | 03:50 PM
  #42
TX Tahoe Z71's Avatar
Originally Posted by skyhighsami
I would think if you can increase the speed at which the water makes it to the exchanger given the volume yours can hold it would benefit from the higher volume pump
That's what I'm hoping, otherwise I just wasted a nice chunk of change
Old 07-15-2010 | 05:18 PM
  #43
kbracing96's Avatar
A high volume pump works with you IF you have a large volume of cool water to keep "flushing" the intercooler with. How ever, it works against you when your flowing that same heated water though a heat exchanger to fast to cool if off. It's about finding a balance of flow for the amount of water you have in the system and the size of the intercooler and heat exchanger and how the system is going to be used. Drag setup with large tank to fill with ice and water, or DD where you depending on heat exchanger to cool the water off.
Old 07-15-2010 | 06:54 PM
  #44
Last Call's Avatar
TOTM: January 2007
I read an article in Chevy High Performance on a Radix 112 in a Silverado SS. They slowed the IC pump down and it lowered the IATs. Basically they said if the water spent more time in the IC, it could absorb more heat.
Just a thought...
Old 06-06-2017 | 01:27 AM
  #45
Ford_Assassin's Avatar
Come Get Some!!
Digging up an old thread....
Pics not showing up....
Any chance you can repost them or email them to me? Thanks!!
Old 06-06-2017 | 08:59 AM
  #46
Atomic's Avatar
Hmm I will see if I can find them. Not sure why that folder in my photobucket disappeared.
Old 06-06-2017 | 02:43 PM
  #47
Come Get Some!!
That would be awesome. I was looking at the 2" thick version, but if you didn't have issues mounting the 3" 101, then that will likely be what I go with.
The shitty part is I have a stock CTS-V heat exchanger, but the water ports and overall size have me scratching my head on how to make in work in my 03 Silverado.
Thanks!!
Old 06-07-2017 | 07:36 PM
  #48
rpm-inc's Avatar
I have that heat exchanger mounted in my 04 2500. Its not doing anything yet, but its there. I will try to find some pics....
Old 06-10-2017 | 12:51 AM
  #49
Come Get Some!!
Cool, thx!!
Old 06-10-2017 | 06:52 PM
  #50
Y-B-Slow's Avatar
On my 05 Sierra, fits behind the grill with a little trimming.
Attached Thumbnails that huge heat exchanger from frozen boost-snapchat-1935904776.jpg   that huge heat exchanger from frozen boost-20170610_165611.jpg
