I think I hydrolocked my LQ4!
Old 07-14-2010, 07:13 PM
  #41
TOTM: January 2007
Last Call's Avatar
Interesting.... I have an Alky Control kit and if my battery goes dead, it will trigger the meth pump on. I didnt wire it or install it, but I do know when the voltage drops, the meth pump will turn on.
I caught most of the tmes this happened because the meth would leak from my airbox and there would be a puddle underneath the truck.
Sorry to hear bro...
Old 07-14-2010, 09:54 PM
  #42
2nd fastest 5.3 ECSB
trever1t's Avatar
weird! How does that work? Maybe I should just shut mine off when not in use? The AlkyControl box does have an "off".... still don't know how that's possible to start pumping at low voltage, where's Dewmanshu with the answer?
Old 07-17-2010, 10:23 AM
  #43
sharpshooter's Avatar
I started taking the engine out last night.I'm going Monday to pick up a 2005 LQ4,I heard the 2005's and newer have a little better internals.
I hope my cam,springs and push rods are fine from my broken 2002 LQ4!
Old 07-17-2010, 12:11 PM
  #44
TURBHOE's Avatar
I think I wired mine to where the key has to be in the on posistion to work. Instead of power all the time or one click forward. I also installed an off on switch inline with the main power source for the controller.
Old 07-17-2010, 08:20 PM
  #45
Rick_Vor's Avatar
What did that LQ4 run you in Delaware? Over here in the SF Bay Area, a decent LQ4 runs $750+. A LQ9 is $1k+.
Rick
Old 07-17-2010, 11:08 PM
  #46
sureshot's Avatar
Damn man, I go on vacation for a week and you done tore your **** up! That sucks, but we'll get her running again!
On a side note, I'm thinking Justin's idea is a good one!
Old 07-17-2010, 11:27 PM
  #47
Banned
1LOW4X4's Avatar
And get a red top optima while ur at it
Old 07-18-2010, 09:35 AM
  #48
Baltimore Whore
Mangled03gmc's Avatar
Russ if you decide to off the old engine, let me know. Buddy is looking for a 6.0 his f bod
Old 07-22-2010, 10:40 AM
  #49
GFYS and STFU
Spoolin's Avatar
Damn that's a shitty way to blow a motor. Do you have a pic of where the meth nozzle is in reference to the intake? I plan on putting mine below the TB so if it does run wild it will flood the cold side piping and not into the intake. Not sure if that will help at all once the engine starts cranking but...
Old 07-22-2010, 04:53 PM
  #50
phasemaster1's Avatar
I think placement dosent matter once you fill cold side and turn over....damage done
Quick Reply: I think I hydrolocked my LQ4!
