ice box set up
Old 12-29-2011, 10:41 PM
Slowest turbo build ever!
black00chev's Avatar
Originally Posted by blwn4.8
The heat exchanger is already on order!
Meth is out of the Q, ive seen what it does to the rotor coating!
I think for now the HEX and spacer will do then maybe put the ice box in in the futture to have it running when waiting at the track
If you get the spacer you may be able to insert spray bars and spray the meth POST rotor
Old 12-29-2011, 11:22 PM
NemeSS's Avatar
That sounds like it may work with spray bars like an old carb nitrous plate. Activate the meth spray with a Hobbs switch.
Old 12-29-2011, 11:25 PM
I have a gauge for that
Atomic's Avatar
Ive done the icebox setup when i had a turbo. It worked awesome but didnt last long at all. Even with 10# of ice.
What worked best for me was to take the HX out of the system loop the heater hoses together at the water pump, route those lines that went to the HX to the heater core.
Running the AC in the summer it blows a lil cooler with the 200* coolant running thru the HVAC. And the 30-40* air from the AC blows over heater core and chills the air nice.
I saw IATs in the 50-60s when it was 100* ambient.
I have no dealing with, a SC just with a turbo.
Hope it helps.
that's very clever, hmmm....
Old 12-30-2011, 01:11 AM
11 Second Hall Moniter
AKlowriderZ71's Avatar
I use an icebox with frozen water bottles at the track. It's done pretty well for me.
I've researched the use of meth with the Radix, and I came to my own conclusion that it really does not do a good job of reducing IAT's on the Radix.
Nonnie's idea is interesting, if you don't need the use of your heater core.
Old 12-30-2011, 01:51 AM
nonnieselman's Avatar
I wouldnt try it at the track
Be done dripped water everywhere from condensation.
But for towing it worked amazing.
Cheap to try too. And the AC actually got a lil cooler since the hot air isnt radiating off the heater core.
chopperloco
07-10-2016 10:45 PM
Sexyrado327
08-02-2015 04:08 PM
maxspeed05V
07-19-2015 07:08 PM
00pooterSS
07-16-2015 03:03 PM
00pooterSS
07-16-2015 02:41 PM
Quick Reply: ice box set up
