Injector help for the 2.3l twin screw
#22
#25
I'll let you know. My trucks already pretty loud from my corsa exhaust, so we'll see if it gets a lot louder.
#27
I don't remember the exact temps but they were much lower than when I didn't have the intercooler. I'll ask them what they were when I pick up my truck this week.
#28
You need to keep the maf as far as possible from the bypass.My maf sits about 4" from the throttle body.SD is also an option that I would /will consider.
#29
What bypass are you running and where do you have it placed in your setup? I think mine is going to be after the blower outlet and but before the intercooler inlet.
We discussed SD but that will make my truck not in compliance with emissions in my area. So for now I am going to try to keep the MAF. In the future I will most likely go to SD when the MAF is actually maxed out.
#30
I suspect you will max the maf out when you dyno it.I am maxing mine out at 5200 rpm with a 3.375 pulley.My cam/heads are good till 6500 for reference.
I would put the bypass on the blower in the original location.I am still on the stock bypass that I did some work on far as porting it a little bigger its like 38mm.
