Injectors for Radix M112 w/2.8 pulley?
I'm prepping to install my Radix M112 kit on my Yukon Denali (LQ4 6.0L), and I'm doing all the reading I can so that I am well-prepared before jumping into the project. One thing that I have read in various forums is that people talk about "running out of injector" with the 42# injectors that are included with the Radix kit. If I'm using a 2.8 pully, with a mild cam, and the other mods listed in my sig, do you think I will be okay with the 42# injectors? Or should I try to set it up with 60#'ers before installing it? If so, are there any specific 60# injectors which are known to fit & work well with the Radix kit?
I'm not planning to anything more to the truck than what I have listed in my sig, so if I'll be okay with 42# injectors then I won't even both with going to 60#. I just want to try to do everything right from the beginning, rather than having to rip stuff out and change it later on down the road.
Are there certain 60# injectors that are recommended for fitment & performance with the M112? And are they plug & play right in place of the 42#, or do you need to make any modifications to the fuel rail for them to fit?
murderedSS
27
10-12-2015 12:13 PM
SlvrSierra4.8
10-01-2015 10:39 PM
