Inlet Forward/Rear Drive TVS2300 LS2/427 L92 Heads and Cam
Old 03-16-2009, 07:36 PM
FormerVendor
leftcoast32's Avatar
Default Inlet Forward/Rear Drive TVS2300 LS2/427 L92 Heads and Cam
I just got back from Arizona at my partners place. We finished the install of an Inlet Forward/Rear Drive TVS2300 on his Darton Sleeved LS2/427 with WCCH L92 Heads and LEP MagnaCharger Cam. We also installed Dual Heat Exchangers and Dual Pusher Fans for the Heat Exchangers. It took some modifications to the firewall and some machining of parts to make it all work. This was all done with a Cog Rear Drive and the IW Overdrive 8 Rib Pulley Setup. We were able to get 14 psi and will add more boost (fuel permitting) as we finish the tune.
Old 03-16-2009, 07:37 PM
FormerVendor
Old 03-16-2009, 07:43 PM
11 Second Club
mike mcginnis's Avatar
damn thats nice! i also see an 8 rib on that 2300!
Old 03-16-2009, 07:46 PM
FormerVendor
This one used a modified 122HH 8 rib pulley due to the shaft design. We are going to look into making a hub to use the quick change hub like yours some time.
Old 03-16-2009, 07:52 PM
Whippled 496's Avatar
Absolutely beautiful! Can you tell me more about that dual crank pulley please? Is that an 8 rib/4 rib pulley. That is exactly how my A/C compressor is mounted on my 496 with the seperate tensioner and everything and I am looking for a way convert my setup to 8 rib. I did not know that was how the small blocks were setup as well or is that something unique to the 7L engines?
Old 03-16-2009, 08:00 PM
FormerVendor
The Aftermarket LS Crank Pulleys have the smaller 4 rib for the A/C and the 8 rib for the Accessory Drive.
Old 03-16-2009, 08:08 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Very impressively clean install....wow
Old 03-16-2009, 08:35 PM
OnyxSilveradoSS's Avatar
do you have an 'after' picture of the fire wall?
great work.
Old 03-16-2009, 08:44 PM
FormerVendor
great work.
That is the after picture of the firewall. We went down to a local paint shop and had some paint mixed to touch everything up.
Old 03-16-2009, 09:09 PM
Bill Reid's Avatar
Awesome project Who is your partner in AZ and where does he live?
Bill
Quick Reply: Inlet Forward/Rear Drive TVS2300 LS2/427 L92 Heads and Cam
