Inline fuel pump going on and off
I have an inline fuel pump to boost fuel pressure. This just started. When I stop and fill the truck or just shut the truck off for like 5mil and start it back up the pump will get real loud and the pump will come on and off for some time. Thought it was a bad pump but put a new one on and it still dose it. Got any ideals??
Little more info may help. The pump is an inline Walbro pump. It only dose this when the truck has been shut off for a short time like at a fill up or run into a shop and back out. It you leave it off for like 30 minutes it will be fine. When you turn the truck on you can hear the pump is a lot louder and it will go on and off for around 3-4 minutes or so then clear up. The pump will say off just lone enough to kill the motor then back on.
Truck Sponsor
What year is the truck?
Get a test light or a simple light inside the truck hocked up to the pumps wires. If the light is on when this happens its either the boosta pump, the pump inside the tank, or a ground issue with the boosta pump.
The pump in the tank stops or has issue will cause a cavitation in the line.
I hooked the pump start to the battery with a switch and the pump runs fine no on off. Checked all the ends of the wires and all checked out fine. Been down a few days hope to be back at it next week.
05GMC4.8
08-07-2015 09:55 PM
Mossyoakglock
07-17-2015 08:30 AM
