Intercooled turbo iat?
Old 06-20-2012, 06:02 PM
Jake99's Avatar
Default Intercooled turbo iat?
What are most you guys getting for iat over outside air on you turbo setups? I have my intercooler behind the grill and im hitting 175 iat in 95-100 degrees outside temps. This is on only 12 psi on a 4.8 with a 76mm turbo, its seemed to high to me, is my intercooler junk? I got it off ebay, its a 31x11 I think 3in thick.
Im running e85 so it works but I have plans on going up to 18-20 psi and I dont see that working to well. What do you guys think? Do I need to look into a better intercooler or is this normal?
Old 06-20-2012, 06:14 PM
Pc2000trk's Avatar
I'm no mechanic but I think that's way to hot , maybe need to try to allow more air across it . I'm running more boost then that and even when I hot lap it on the street I've never seen over 150deg - the e-85 helps with your temp but for me personally that's a red flag . Can you do some cutting to get more air to it ?
Old 06-20-2012, 06:27 PM
Mod with training wheels
smokeshow's Avatar
During the day, that's no surprise. Ambient here at night is around 90 or so, and I see IATs approaching 150 after a good 10-12 seconds WOT on 15ish psi. I have a decent intercooler too...
Old 06-20-2012, 07:17 PM
lglowe's Avatar
I have a eBay intercooler and I just added a meth kit and I'm seeing around 12* below ambient temps on about a 9 second street pull. Temps outside where around 92 or when I did that.
Old 06-20-2012, 08:43 PM
03sierraslt's Avatar
Wow, my TVS doesnt hit those temps at 12psi and everyone says Maggies are wafflemakers.
Old 06-20-2012, 08:45 PM
I AM A MOTHERF*CKER
TurboBerserker's Avatar
Assuming your IC is getting good air, I would seriously consider a better IC...
Old 06-20-2012, 09:44 PM
Jake99's Avatar
Hhhm, You can see about 60-70 percent of the intercooler throw the grill of the truck, so I think is getting good air flow, I just dont think its cooling near what it should, 175 seemed very hot to me but im kind of new to boost so I wanted a little input on this, This numbers is what I hear alot of people getting without the intercooler. So now.. whats a good intercooler that decently priced? Mines a 120 dollar ebay one and it seems to be junk.
Old 06-20-2012, 10:59 PM
lglowe's Avatar
How is your air filter setup? If its right on the turbo its only sucking up hot air to start with
Old 06-20-2012, 11:25 PM
nonnieselman's Avatar
Its not cheap, but you can take a look at what foose04 got. I wanna say his IATs actually dropped through out the pull? Instead of rising like the cheap intercoolers do.
Old 06-21-2012, 05:15 AM
Jake99's Avatar
Air filter is down maybe 18 inchs off the turbo, I tryed to get it as far away as I could from heat but theres only so much room, its better then right off the turbo but not really pulling in cold outside air like you would want.
Quick Reply: Intercooled turbo iat?
