Intercooler with Heat exchanger
I have a 06 silverado, I'm using a turbo setup, and I want to have really good IAT temps. I was thinking of a air to water intake manifold intercooler. Like the tick performance intercooler, and I was looking into heat exchangers to put in the bed. Does anyone recommend just using a derale fluid cooler with fans?, do you think that cooler would cool enough to keep the fluid temps down other than using a full radiator in the truck bed.
I have a gauge for that
When it comes to coolers the bigger the better. The main advantage of A2W is youre able to add ice to the tank or use an interchiller type setup to bring the water to below ambient temps. If you dont plan on doing either of those then a good A2A is a better choice.
