Intercooler Piping
Old 07-11-2008, 02:20 PM
ZZebes's Avatar
Default Intercooler Piping
I'm using some 3" 16ga aluminum pipe i got off ebay and besides being almost oval it's just to soft to use
what are ya'll using for your cold sides???
i didn't want to use 16ga mild cause of rust but i may have to and just have it powdercoated
Old 07-11-2008, 02:22 PM
FormerVendor
Derek @ EDO's Avatar
16ga stainless on mine.
Old 07-11-2008, 02:26 PM
Resident Retard
BlackGMC's Avatar
You could use Aluminized steel instead of mild steel...
http://store.racing-solutions.org/mandrelbends.html
Old 07-11-2008, 02:27 PM
ZZebes's Avatar
Can i weld Aluminized with a standard tig
i can't afford a High Frequency for aluminum lol
Old 07-11-2008, 02:29 PM
Resident Retard
BlackGMC's Avatar
I weld it with my Mig w/gas... It is just a thin coating that is on the outside of the steel... If you grind on it the coating will come off...
Old 07-11-2008, 02:30 PM
Resident Retard
BlackGMC's Avatar
Aluminized Steel (A787) is electro-coated mild steel. It has similiar welding properties to standard mild steel. It can be stick, mig or tig welded.
A little info from the website I posted above
Old 07-11-2008, 02:38 PM
FormerVendor
IMO aluminized steel does not weld very nice. it is very similar to welding galvanized steels. don't expect fabulous looking welds out of this stuff.
I could see using it for the Hot exhaust side but it wouldn't look great for a cold side application. The coating acts like a contaminate when welding, it would need to be cleaned throughly.
I would go with stainless and not look back.
Old 07-11-2008, 02:43 PM
ZZebes's Avatar
I Probably will end up with stainless since i can tig that and reduce the amount of Clamps to explode at 20lbs
****'s Just expensive lol
Resident Retard
BlackGMC's Avatar
I would disagree, I have no problems welding it, all I do is angle the edges with a table top belt sander and that is it...... Also the majority of the Catback exhaust systems sold are with aluminized steel...
Old 07-11-2008, 02:54 PM
FormerVendor
But it was mig welded, completely different procedure.
Tig welding aluminized will be a headache.
Tig welded stainless is gorgeous.
Mig welded aluminized is not near as cosmetic but will work.
I would go mild steel or stainless, if you go mild just paint it with DEI's HI-temp silicone coating.
I just believe it should look as nice as possible, you've already spent loads of cash, dont skimp on the cold side.
Quick Reply: Intercooler Piping
