Issue with SD tune ET Closing due to boost
I have an issue with SD tune using 3-bar GM old style map sensor.
Tuner is battling an issue with ELectronic Throttle Body closing when ever it builds boost.
Threshold map table for ET is 105. He set it to zero using EFI live and done some changes but it still commands TB to close as soon as it goes into boost.
Error code is 1514.
Any help is appreciated before we revert to MAF tune.
Error code is 1514.
However, he set table under Engine diagnostics-ETC-ETC to max value, it's above 4000.
But we switch to stock 1-bar map and tuned it SD on stock map to 15 psi for the time being until we figure out the issue with 3-bar SD map tune.
