Jegs oil separator works
If your looking into a catch can set up, this is a very inexpensive choice.
Seems to be doing its job very well. I'm suprised, but pleased that there is no oil in the separator inline of the Procharger inlet. The separator inline with the pcv hose seems to be catching its fair share of oil. Now that I have slowed down oil inlet into the intake I plan to do a top engine/intake cleaning.
I have changed up a couple of things too. I took off the breather filter and reinstalled my oil cap. I also switched froma regular pcv valve to a fixed oriface pcv valve(note-do not run a fixed oriface valve on a boosted set up without installing a one way check valve inline)
Here is a pic of the separator inline with the Procharger inlet. Still looks new,no signs off oil. Good to know there is no oil getting in the intercooler and all over the MAF sensor.
Here is the one inline with the pcv hose
Originally Posted by 02BlueStepside
Looks good, I need to look into this. How exactly is everything setup?
The other oil separator just went inline, inbetween the pass. side valve cover and procharger inlet.
