JGS Wastegate... Need More Boost!!
#34
I'm having the same issue, I'm gonna replace the spring with a softer one and see if that helps
#35
I've taken the spring out and still boost to 15 psi I got on it today in 82 degree heat and boost went to 10 psi with the spring in not sure what els I can do I think I might go with the percsion pw66mm wastegate and call it good what do u guys think
#38
I had boost spikes also when the wastegate was located on the crossover so i decided to move it right on the 90 degree elbow before the turbo, solved my problem... My take on this is the waste gate needs to be closer to the turbo which should eliminate some of the back pressure, it will let the excess exhaust out before it spikes the boost.... Has worked good for me
#40
