Joe Gibbs 4.8 Radix question
Old 03-03-2010, 10:30 PM
TurboGibbs's Avatar
Originally Posted by GMC_DUDE
I did the same shortly afterwards. In fact you were the inspiration. The 3.25" pulley made 10 psi boost. My maggie came with the 42 lb. marine injectors, and they were fine, but at their limits (about 85% duty cycle IIRC). The stock maggie tune was pretty much OK as well. I only had to tweak the power enrichment cut-in to avoid a lean spot where I would have 1-2 psi boost but still stoich AFR. BTW, still have the maggie (almost 6 years now) and it still runs great.
EDIT: Should mention, this was for a regular truck with an aftermarket maggie kit, not a Joe Gibbs truck.
Yeah, I remember that. I wish I would have stopped there.
Old 03-03-2010, 11:06 PM
makes children cry
_zebra's Avatar
Originally Posted by hellbents10
...Should be fun till the 5sp breaks!
i believe his trans will be fine. there's a RCSB guy beatin on his with an 8.1 & still running strong (even after the abuse from his 454). i even talked to a guy from JGP a few weeks ago & he said they never had any problems with the transmissions with the power they were making
Old 03-04-2010, 08:22 AM
TurboGibbs's Avatar
I went a 12.58 1/4 and 445/489 pwr to the wheels on mine. Never broke.
Old 03-04-2010, 01:31 PM
makes children cry
_zebra's Avatar
nice!!
but it still stinks for me because before i learned what all this trans could take, i decided against the 6.0 so i would keep my trans 'safe'
now that the new's wore off, i'm starting to wish i'd've gone 6.0
Old 03-04-2010, 01:36 PM
TurboGibbs's Avatar
I don't know where the 5 speed got it's bad rep. I think it is from the 4L60e boys jealous since theirs can last beyond a couple of bolt-ons.
Old 03-04-2010, 05:37 PM
makes children cry
_zebra's Avatar
true that!
heck... even the 3/4ton dodges used the same NV3500 (just with the s10 gearing & obviously the dodge bellhousing/input/output shafts)
what i thought was funny was that the LD2500s got the regular nv3500 while the 4.7 dakotas got the nv3500HD (a little higher torque rating & different gears)
Turly56
11-13-2015 01:00 AM
89sierra
08-19-2015 07:13 PM
USMCvet0311
08-01-2015 07:45 AM
Ketis
07-23-2015 12:37 PM
Quick Reply: Joe Gibbs 4.8 Radix question
