June Speicals. Turbo'ing the world one truck at a time. :)
JUNE SPECIALS
These specials are only good tell the end on June..
With tax incentive checks being mailed-out, this is the perfect time to get one of our turbo kits.
TrickPerformanceProducts is offering you: FREE Freight, a wideband controller, or a wideband controller and sensor with your product purchase.
A wide band is a must for anyone who is tuning their own truck or wants to keep an eye on the air/fuel.
The wideband controller box can be mounted anywhere and is water resistant. The unit will plug into an FJO gauge or into your tuning software, with its analog outputs.
Hot pipes are stainless steel, and tig welded.
Cold pipes are aluminum, and bead rolled on the ends to keep the silicone hoses in place.
pic shows coated pipes with coated housing. Coatings are extra.
Hot pipe kit.
INCLUDES:
Crossover with flex joint,
Manifold
3” down-pipe
flange o-ring gaskets
and bolts.
$2300.00
& FREE FREIGHT
pic is showing coated pipes, coatings are extra.
INTRO kit.
INCLUDES:
Hot pipe kit,
62-1 Turbonetics watercooled turbo
38mm waste gate
blow-off valve
cold pipe
silicone couplers and clamps
oil pressure line kit
oil return line kit
5/8 water line and turbo fittings
Cone air filter
$4254.00 + freight
FREE WIDEBAND CONTROLLER1
Street Stalker kit.
INCLUDES
INTRO KIT UPGRADED TO A 76MM TURBO
$4654.00 + freight
FREE WIDEBAND CONTROLLER & BOSCH SENSOR2
INTERCOOLER KITS FROM $700.00-$1600.00 DEPENDING ON APPLICATION and TYPE OF INTERCOOLER.
PURCHASE A TURBO KIT plus any INTERCOOLER KIT AT THE SAME TIME AND RECEIVE FREE FREIGHT + YOUR FREE PRODUCT..
1) FJO wideband controller KWB4000 only.. $199.00 value. Sensor sold separately.
2) FJO wideband controller KWB4000 & Bosch Sensor. $269.75 value
These specials apply only to retail customers.
Hot pipe kit.
INCLUDES:
Manifold
3” down-pipe
and bolts.
$2300.00
& FREE FREIGHT
INTRO kit.
INCLUDES:
Hot pipe kit,
38mm waste gate
blow-off valve
cold pipe
oil return line kit
Cone air filter
$4254.00 + freight
Street Stalker kit.
INCLUDES
$4654.00 + freight
Hmmmm.
Damn... wish I was in the market when you guys put that special "big" pipe kit together. I got no complaints on what I have... just what you guys put together for the really big HP guys without chopping **** up or removing creature comforts impressed me. Good Job! Damn gas prices are killin me... yet I can't keep my foot out of the throttle!!!
Bill
Bill
The hot pipes will fit the NNBS. We used our 07 Avalanche for the build. The ic gets a little tricky but I have one we pulled off the Ava. 4.5 core, depending on several things in the front end if it will fit or not.
We could do a water to air set up...
let us know if we can help any..
Rick
Rick
