June Speicals. Turbo'ing the world one truck at a time. :)
Will this kit fit a 2000 2500 6.0 4x4 truck? Really looking into going FI and its between this kit and a procharger. Obviously the turbo would provide better low end (well probably more power everywhere) but a used procharger is so cheap. Hmmm, decisions, decisions. What kind of power would this kit put down on a stock 6l setup and does the exhuast connect up to a stock catback? Thanks
Yes it will fit. The power really depends on the boost settings. With a 6.0L I would do a 66mm or larger turbo. 500+ DD is well with the engine ability. I even have a custom exhaust that was built for my 02 2500HD Xcab.
The routing goes, single into dual cats, huge magnaflow muffler, and 4" up and over the axle.
Could work nicely on your set up...
Rick
Rick
The hot pipes will fit the NNBS. We used our 07 Avalanche for the build. The ic gets a little tricky but I have one we pulled off the Ava. 4.5 core, depending on several things in the front end if it will fit or not.
We could do a water to air set up...
let us know if we can help any..
Rick
Rick
I used to be a procharger guy and switched to a turbo. The turbo is way more fun then the procharger, definately worth the extra money.
