Just bought a Trick Stage 2 Kit – any input, tips or tricks?
#22
I cant understand the point of having power (turbo) if your not goin to beat up on it. I ran the crap out of mine and kept breaking transmissions. i towed alot and had it to the floor alot.
If you ever have any transmission trouble just weigh your options on a built 60E or a 80E.
good luck with your new found power![Grin](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_grin.gif)
i just sent some money for my new turbo setup![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
now put that 5.3 on 20psi in a mustang and you have something.
LaBlackIce (05-12-2018)
#24
Guys quick question
where do I put the one way valve to keep from having positive crank case press? the vacuum / boost port on the pass side of the manifold or the vaccum line that use to go to the intake tube?
I also started installing my gauges. The fuel pressure is 60 on the cold start and about 1 min after drops to 43psi. idle and WOT it stays right at 43. is this what you guys are seeing too?
did you guys light your gauges using the 87 pole on the headlight relay or pull power from under the dash? i am thinking about changing the power and light source to under the dash and both on with key on.
I bought new exhaust gaskets too just incase.
UPS says kit should be dropped off today
#30
oh really? hell if i didnt have blackbear i was gona have them do some tuning down the road or at least hit the rollers for a baseline. seemed like a cool buncha guys, i actually hit up them for a job as a cad drawer or something designing new parts but they didnt have any of that lol.
