Just bought a Trick Stage 2 Kit – any input, tips or tricks?
Old 06-13-2012, 03:34 PM
  #71
thunderwagen's Avatar
That should have a different flange on it than your WG. If it is under the truck and isn't pointing at anything the heat will burn up just let it dump straight out or route it into the exhaust if you dont want to listen to it.
Old 06-13-2012, 06:25 PM
  #72
Choda's Avatar
I'm worried about **** getting into the valve like dirt and salt.
Old 06-13-2012, 08:23 PM
  #73
Choda's Avatar
Drove it around the block and it went into limp mode. Threw the stabalock, traction control, check engine...etc. Is this from the rear o2s not plugged in?
Old 06-13-2012, 09:33 PM
  #74
holley2346's Avatar
If you don't have a tune yet you better not get that sucker in boost!
Old 06-13-2012, 10:31 PM
  #75
Slowest turbo build ever!
black00chev's Avatar
Old 06-14-2012, 06:19 AM
  #76
Choda's Avatar
I didn't. Not even above 2500 rpm. It wasnt the rear o2s that threw it. It was the 4cyl mode. I kept it from going into v4 mode by leaving it in 3rd gear and it drove fine. On the way home got up to 17/18 af ratio while cruise though. Didn't like that
Truck is done being built. Just need tune now
Old 06-14-2012, 07:00 AM
  #77
holley2346's Avatar
Truck is don't being built. Just need tune now
Im guessing since you drove around with a stock tune you still have stock injectors.... You staying around 3 pounds of boost or what? Or is your truck flex fuel and theyre already a little bigger?
By the way, the building never ends. Once you feel that boost youll want more and more and more.... Cam meth more boost transmission. I originally planned to be turbo on premium gas, 6 pounds using the maf. Stock transmission and all that..... Needless to say that was like 7 months ago and ive went way further.
Old 06-14-2012, 08:38 AM
  #78
Choda's Avatar
holley I def know the feeling, i started with a 15 sec mustang when I was in 11th grade now i have a street car that does wheelies and runs mid 9s in the garage. lol I have a sickness
Yes stock everything and a flex fuel truck. So i will be keeping it at 4psi until I build up the golden chest. Ill be happy knowing I have the first boosted gas truck in Western New York. Itll make decent power and run like a champ. When Im ready Ill go on kill and buy a trans, injectors, pump and all supporting mods to hit my 500 wheel goal.
A good eye can pick up the intercooler behind the grille, looks nasty
Old 06-15-2012, 09:04 AM
  #79
formerly slow03 (11-04-2011)
slow2008's Avatar
Where in the area are you at? I'm in Lockport.
Old 06-15-2012, 03:02 PM
  #80
Choda's Avatar
Amherst txt me 716-957-0377
Quick Reply: Just bought a Trick Stage 2 Kit – any input, tips or tricks?
