Just bought a Trick Stage 2 Kit – any input, tips or tricks?
Old 05-16-2012, 05:28 PM
Choda's Avatar
Thumbs up Just bought a Trick Stage 2 Kit – any input, tips or tricks?
Bit the bullet and called Rick. Stage two kit with open dump, turbo blanket, thermo-sleeve, extra wide-band bung and the MAF welded for my 09 1500 4x4 4L60 ext cab short box flex fuel truck.
I’m very excited to see how it goes together, reg drives and under WOT pulls. Right now with a dyno tune, Volant intake and muffler - I’m right under 300 rwhp. I’m shooting for a daily 400wheel on 93 pump.
Any tips of tricks you guys have for me before the install?
I’m going to replace both heater hoses with new 5/8.
Put a check valve in the PCV line to keep positive pressure outta the crank.
I have tr6 plugs in it now, should I go with the 7s with a 6-7psi?
I have the line pressure increase and the tq management pretty nasty ( it chirps 2nd once in a while)… should I get the vette servos also? Do the servos do the same thing as increasing the pressure? If I should upgrade, should I get both the 1-2 and the 3-4? And where should I order them from?
I am having my tuner tune it with his HP tuners, he has a lot of experience with FI LS motors.
Should I wrap the manifolds and crossover?
What port do you guys connect your boost gauge to?
Stick with mob1 oil?
What am I missing guys? Any help is appreciated.
~Jacks
Buffalo NY
For those looking for pics and steps for the install read this thread I just created with pics - https://www.performancetrucks.net/fo...s-pics-521152/
Old 05-16-2012, 07:25 PM
Red Truck's Avatar
Congrats! Ordered my 76mm kit from him last week, very anxious to go get it.
Old 05-17-2012, 12:57 PM
Truck Sponsor
TrickTurbo's Avatar
Thank you very much for the order.
Lay the kit out on the shop floor prior to doing the install. Look all parts over and call me if you have any questions. You can install the inter cooler first without any down time on the truck. The install will take a solid weekend once you start pulling the exhaust off.
will look clean.
good move
I would think Tr6 will work for your application.
sorry no help here on this one.
I would not wrap the crossover. You might get some thermal boot sleeve for the plug wires. YOu are already getting the blanket and a wrapped down pipe. The rest of the heat is in the same location it was before going turbo.
Passenger side of the intake under the engine cover. There is a vacuum port with a plastic cap on it. Just twist cap off. This will be the source for everything. Gate, BOV, gauges etc.
Yes, full synthetic
~Jacks
Buffalo NY
Looking forward to getting a boost truck up in your area. Again thanks for the order.
install link
Old 05-17-2012, 02:40 PM
Choda's Avatar
U are wrapping the down pipe for me? Awesome!
I will def get the thermo sleeve for the wires and plugs. Last night I was looking around the engine bay and noticed a couple other things.
1. Do I have to modify the oil dip stick, tranny dip stick, oil filler tube?
2. Getting to the firewall for the hoses is gonna be a BBBBBB
3. the oil feed part next to the filter does not look like the one in the GMC install. It felt like a cover with no ports or threads or anything. Two bolts hold it in place. Does the kit come with the adapter/fitting I will need to connect the feed line?
this guy .. http://www.trickturbo.com/2010%20GMC...3_4286_jpg.htm
Thanks again Rick, I cant wait to get this thing going. Im going to the dark side with this project. Im a nitrous mustang man and now selling the car and boosting my chevy truck.... these are the times that try mens souls =]
Old 05-17-2012, 04:30 PM
smdusaf's Avatar
thats because you dont have a engine oil cooler. he makes a peice for it still that bolts right to it just let hime know no cooler
Old 05-17-2012, 04:53 PM
thunderwagen's Avatar
It actually goes together pretty easily. I got to the point I could put the system on in just a couple of hours.
Make sure your oil drain is above the oil level.
Get the block for the feed line from Rick if you dont want to drill and tap what you have.
reroute your heater hoses along the fender to keep them away from the heat.
slide the down pipe in from the bottom before bolting on the log manifold.
leave everything a little loose till it is all bolted together then tighten it down once you are at that point.
Save up for a transmission cause yours is gonna tell you thanks for playing!
If you have any questions definetly call Rick cause he has exellent customer service.
Old 05-17-2012, 11:00 PM
REDNREADY07's Avatar
The kit goes together really easy i had no issues its an awesome kit
Old 05-17-2012, 11:24 PM
Choda's Avatar
Thanks guys. Ill call him tomorrow about the oil feed. Pos is a 1500 4x4 ext cab and doesn't have a oil cooler??? Lol
Good tips thunder wagon. :tup:
Old 05-18-2012, 06:32 AM
Truck Sponsor
TrickTurbo's Avatar
You will be able to slide the down pipe in with the manifold and crossover together. Thunderwagons kit is a little different layout.
Removing the front passenger tire and fender skirt will give tons of room to work.
Old 05-18-2012, 07:44 AM
Choda's Avatar
Rick I need the oil adapter please.
Quick Reply: Just bought a Trick Stage 2 Kit – any input, tips or tricks?
