KB Racing FULL Intercooled kit!!
#23
With your body lift, you would probably have to do some reconfiguring of the intercooler mounting and tubing since it bolts to the radiator support which is 3" higher in your truck.
#27
something else
I have heard that that is one of the resons that turbo's fail, not enough oil or dirty oil, and when you have oil dirty in your turbo that would go into your motor as well, correct?
#28
I would never be able to afford that any ways. How much sooner does your fron mount start to spool? Can the turbo run off of it's own oil tank, instead of the oil pan?
I have heard that that is one of the reasons that turbo's fail, not enough oil or dirty oil, and when you have oil dirty in your turbo that would go into your motor as well, correct?
I've only heard of a couple of rear mounts that that have had self contained oil system. A turbo is not going to make oil dirty, nothing it in to dirty the oil unless it where to fail really, even then still not much in them.
