KBracing Turbo Kit with OBX headers (G Body)
Specs as follows
Engine
4.8 shortblock from 2010 truck
Stock 853's
Ls7 lifters
Copper coated ls9 gaskets
Kmj studs
ARP Rod bolts
Holley Hi Ram
Stock TB
BTR .660's
218/218 112* camshaft
Boost leash boost controller W/C02
Holley HP ECU
Still debating on putting good rods and pistons in a 5.3 and selling this 4.8 or just running it
Drivetrain
Built Th-400 W/ Trans brake
Custom PTC Converter
Moser 9" Full spool & 3.70 Gear
Suspension
TRZ anti roll bar
TRZ double adjustable uppers and lowers
Strange double adjustable shocks
Fuel system
Magnafuel 4303
-10 feed/return
Billet atomizer 225's
Turbo kit
OBX LS Turbo Headers
2.25" Crossover
S475 83mm turbine
X2 XOS Power 44mm wastegates
X2 RPS BOV
Frozen boost 2000hp Type 12
Chiseled 7Gal tank with Rule 2000 pump
KBracing will be doing the turbo kit, turbo will go in the grill and the intercooler will go wherever it fits best. I will post more pics as progress is made.
Engine
Stock 853's
Ls7 lifters
Kmj studs
ARP Rod bolts
Holley Hi Ram
Stock TB
BTR .660's
Holley HP ECU
Drivetrain
Suspension
TRZ anti roll bar
Fuel system
Magnafuel 4303
-10 feed/return
Turbo kit
2.25" Crossover
S475 83mm turbine
X2 RPS BOV
5.30's... its an 1/8 only car. ive seen several gen3 motors run 5.5x's with relatively weak 60's and i plant to be in the .20's for that ET Goal. I honestly dont think it will be an issue with the gen4 4.8
im not sure... i am likely going to runn 243 or 799 heads. I copy and pasted this from ls1tech when i planned it a few months ago and a few things have changed lol.
