KBracing Turbo Kit with OBX headers (G Body)
Good luck with the build, I have an 81 Malibu setting on the side for a build someday. This will be a fun project to watch.
Foose04 ran 40k miles boosted, and just broke 900rwhp right before it let loose. I still think the reason it let loose was becaugoine rings touched and broke the piston. He was also running E85 so the piston stayed cooler as I assume will be in this build too with a 225lb injector.
And yea im running E85 aswell as the a/w so I shouldn't see over 70* iat's with ice in the tank and turbo full tilt. This turbo was just to get the build going but I will likely switch to 76R with 92 or 96mm turbine wheel.
I went with the 83mm turbine cause I knew I was going to need a strong 60" and 330" and was afraid the 96mm turbine was going to sacrifice too much low end and mid range power for this 290ci motor...Hope I made the right choice!
Mod with training wheels
All these giant cams have made people rush for giant turbines lol. I'm with you, I went smaller on the turbine this time around than the current 'norm'....not expecting it to be a slouch at all
