Kenne Bell compressor maps/max rpm???
Old 01-29-2008 | 09:27 AM
Default Kenne Bell compressor maps/max rpm???
I'm trying find a compressor map for the 2.8L high output Kenne Bell. OR the max rpm it can be spun. Anyone have this info?
Old 01-29-2008 | 12:16 PM
408 Sleeper's Avatar
With the 2.4 HO I had, Kenne Bell told me that it could be spun to 19,000. The Ford guys are spinning them to 21,000, but the manufacturer(who was Autorotor) said a 15,000 max. I found however that 13,000 was a realistic max, anything over that and the discharge temps went sky high 270+ degrees, and id did not take long before everything was heat soaked. Based on my results with the 2.4, the 2.8 might be good for a mild 6.0 and nothing larger. My 408 had a larger cam and ported heads. I could only get 7lbs out of the 2.4 and that was taking it up to 18500. I would have needed around a 4.0 to handle my 408.
Old 01-29-2008 | 12:28 PM
zippy's Avatar
https://www.performancetrucks.net/fo...d.php?t=390128
This post here has the most info I've seen on that blower. I also haven't found any compressor maps for the Big Bore series blowers.
Old 01-29-2008 | 03:16 PM
yeah, i've been talking to corey about his setup. Mine will be very similar. I've been trying to call KB all damn day and keep getting a busy signal. I'll keep trying.
KB says this particular blower is at it's optimal operation from 12-24lbs boost.
Old 01-29-2008 | 04:06 PM
just spoke to Jeremy at KB. the blower can be spun safely up to 18,000rpm.
the smallest pulley they make is a 3". I've got a 7.25" crank pulley. If I shift at 6000rpm, i'm still well within the blower's limits. How much boost will that make? only time can tell. can i push that much air on 93 octane with no methanol? again, only time will tell. the pulleys are about $70 a piece so if an adjustment in boost needs to be made, no big deal.
Old 01-29-2008 | 06:46 PM
Stoichiometric's Avatar
Have you checked out the Whipple 3.3? I thought a 3.3L with the 10 rib kit would look good on a 408.
Old 01-29-2008 | 09:48 PM
whipple doesn't make a "kit" for our trucks. 2 years ago they told me it was coming out in 6 weeks, lol. last week they told me it was coming in a few months. I was told by i forget who that the 10 rib setup is too thick if you are using efans. i have no proof of this obviously, but that's what one of the pulley manufacturers told me. i forget who.
Old 01-29-2008 | 10:03 PM
Sounds like the release date might be unknown for the Whipple. If you were to run a 10 rib I guess you could run pusher fans from the front of the radiator if they clear your heat exchanger set-up.
Old 01-30-2008 | 02:32 AM
stock48's Avatar
9 Second Truck Club
I wanted to go KB at first, but they are really hard to get ahold of, and I couldn't find many happy KB customers. You might want to check out the new Magnachargers-TVS1900, and a biger one in the works. With the luck you have been having I would stick with something proven. If the KB would be half of what it's supposed to it would really be something. How fast are you looking to run?
Old 01-30-2008 | 08:48 PM
the KB is already ordered. I've had great luck with them so far. I call, they answer, done. There were a few times I got a busy signal but that's with any business. My goal is 11.5sec 1/4mi
Quick Reply: Kenne Bell compressor maps/max rpm???
