L33 and turbo boost.
Is there any reason not to go with this engine for a mild intercooled turbo setup (max 6 psi)? Engine will be left stock except for the turbo. Also, what, except for aluminum block and higher compression ratio, is different on this motor to give it the extra power? Seems like the iron block 5.3L is about 25 hp less.
03regcab sierra
20
08-03-2015 12:11 AM
