Larger Cooler for my maggie, suggestions?
Old 06-04-2010 | 08:51 PM
  #21
Prime Power's Avatar
Vinci sounds nice but the price is way too much for me. Think I'll go the lingenfelter route. Thanks
Old 06-04-2010 | 09:23 PM
  #22
TurboGibbs's Avatar
Originally Posted by blownss06
Turbogibs, how did that Jegs radiator work out. Did it maintain lower iat while crusing and at wot. Also did you keep the stock bosch pump.
I used the stock pump and it kept IAT's lower all the time. I was able to add 5 or so degrees of timing at WOT and that gave me several more hp on the dyno. Im thinking 20 rwhp or so.
Old 06-06-2010 | 03:08 AM
  #23
caddy03pimpin's Avatar
i got the tank in the rear and i have the mazire pump running the big heat axt. from magg. and a 30x12x4 intercooler up front too but its hard to fight these iat also got meth just waithin on my tunner to use it the diff is that im running a 2.4 pullie oooh i forgot to mention this truck hauls ***
Old 06-06-2010 | 06:16 AM
  #24
Where did you get your cooler? Thats huge.
Old 06-06-2010 | 09:59 AM
  #25
RibeiroBJJ's Avatar
Praise The Lowered
I had the Fluidyne Ford lightning heat exchanger with two 7" fans behind my bumper on my SSS with a Maggie..I also had a 1 gal fuel cell used as a ice box in the orig battery location ..with ice I would see 5-10 degrees below ambient..
Old 06-06-2010 | 10:06 AM
  #26
trever1t's Avatar
2nd fastest 5.3 ECSB
Originally Posted by Prime Power
My IAT's are too high and I need a larger liquid heat exchanger for my 5.3l avalanche magnacharged. Any suggestions? Preferably hook ups on the same side, the driver side. Thanks
Can you please tell me what your setup is? Pulley size, IATs?
As already suggested you can double up your XRs, add fans, add methanol/water injection. A larger or increased XR surface does not keep IAT's down but slows the increase in temp and allows for a faster recovery.
At least this is my personal experience. I use the CTS-V HXR from Magnuson, it's 28x14x1 iirc?
Old 06-06-2010 | 10:19 AM
  #27
fastnblu's Avatar
Bill, I've been checkin this thread out & the other 2 or 3 floatin around. IDK if u saw my post in my FI thread, "Cat...", but that CTS-V isn't cheap. Not as cheap as I wanted it to be.
Think it'd be less $ if I went thru Rick? Cause what Maggie direct wants is crazy!
PM sent.
Old 06-06-2010 | 10:22 AM
  #28
schino's Avatar
anyone ever look at the nascar, imca coolers and radiators? these are usually thicker but very nice c&r coolers. even if you use the core only and or have to modify the end tanks these things are about 800 new and you can get them for a little over a 100 bucks. just a thought if you got the room
Old 06-06-2010 | 12:06 PM
  #29
OLD NO.7 Avalanche's Avatar
I am also fighting IAT isues too. On a local drive in N.Y. I Reach 125degs. #7
Old 06-06-2010 | 02:36 PM
  #30
I have the Magnuson stock pulley. Don't know it IAT's when I tow, that is where the issue is.
Quick Reply: Larger Cooler for my maggie, suggestions?
