Launching under boost, Brakes will not hold.
How do I change this text
The more I tune the trans torque converter to slip less during lock-up, the less amount of boost I can buld before my brakes are overpowered.
Acording to my G-tech my best 60' time is 1.92, wich I'm very happy with but in order to cut that low of a number the truck's brakes are under a huge amount of strain (sp) and the truck is hard to keep in one place for very long.
I think I rember F8l Z71 and parish talking about abs comeing on and letting the truck roll, but I'm not sure.
Also I would think upgrade brakes and rotor would help me too right?
You can get more braking power by doing the TY Shuflle. Drop the truck inot neutral, rev it while pressing on the brake, let it idle back down then go back into D. You can feel the pedal drop a bit more. The extra vacuum generated gives the brake booster more power that you can hold.
9 Second Club
quicksilverados will hold 5psi i know...around 3000rpms...enuff to do a 1.65 60'
oh snap..i forgot...get you a harlan 2 step!!!! that will help make more boost on the line at the same rpm
