Launching under boost, Brakes will not hold.
#21
Originally Posted by quicksilverado
A 2-step plugs into the wiring harness between the pcm and the coil packs. You set it to a specific rpm. Once the rpm is set you then stand on the brakes and hit a button to engage the 2-step. You then put the gas to the floor. When the rpms hit the preset, it will rev to that point and stay there and the motor fires on every other cylinder and then alternates to every other cylinder. When you release the brakes the engine begins to fire on all cylinders. At this point if you are on slicks hang on because its like being shot out of a cannon. Hope that helps. I am currently launching at 2800 rpm.
#22
Originally Posted by zippy
if you're using the right converter all the 2 step is going to do for you is make your launch more consitant. the idea behind the 2 step is to be able to go wide open at a low rpm. you'll get alot of air moving through the engine with the throttle blade wide open allowing more to get out the exhaust and therefore more spool. to me the only good way is with the correct converter or a transbrake if you are running that type of converter. the easiest way is to go off idle with a progressive nitrous system coming off the line with a 150 shot and fading to a 75 shot.
#23
Originally Posted by vanillagorilla
Thanks for the explaination. But how do you know what rpm to choose. It seems no matter what you have the 2-step set to, your stall will still be a limiting factor. Since the engine is making less torque not firing on all cylinders and hence more load, I would imagine it would stall even lower.
#24
The bad part is things that work well at the track may not be the best for the street. I like a t-brake, but to my knowledge none are available for the 4l80e.
#26
Where pretell, does one get a 2-step? I looked at MSD's site, and their 2 and 3-steps don't exactly seem to fit the bill.
#27
He has a new design that may be out if Feb. I got an email from him a couple of days ago about it. No set price yet, but new design should be even better than the old.
#28
You might try some pads that are a softer compound, they will wear out quicker but should give you more grip. I'm not familiar with your year truck, but if you have shoes on the rear you could also try running two lead shoes of softer compound on both sides. This would mean you would have to buy two sets of rear shoes to get the four lead shoes, but it would increase your brake shoe area by about a third....
#30
How do I change this text
![Werd](https://www.performancetrucks.net/forums/images/smilies2/werd.gif)
That's what I'm saying....just get a looser converter.
![The Judge](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_judge.gif)
My stall is loose, but with my forcing tables all changed to help slip during lock-up, my stall speed has went down. I just thought there was a easy ABS solution.
