Lc-1 wideband haters
Old 07-09-2013, 04:13 PM
foose04's Avatar
Default Lc-1 wideband haters
Just ordered a AEM today and I can't wait to get this damn LC-1 out of my truck. I wanted to see how many others have had issues and hope to steer people away from this damn thing. Mine has ate 10-12 sensors in 3 years, always needed recalbrations. I have tried grounding from different points, engine block, direct to battery, doesn't matter. It was located about 8" off the down pipe of the turbo, 12 o'clock position.
I hope the AEM will be a better choice. I had a Ngk wideband on my talon for 3 years, never had a sensor fail, worked like a champ. However I need a gauge style mount for the truck so I went AEM based on locals feedback.
Old 07-09-2013, 04:16 PM
GMCtrk's Avatar
My lc-1 was a pile of ****. Damn thing wouldn't work every other time I had the truck on basically and had to shut the truck down and restart it to get the wideband working again.
Have the NGK wideband now and it works perfect except for the ridiculous square box display.
Old 07-09-2013, 04:22 PM
carbongmc's Avatar
I have an AEM Wideband on mine and I haven't had one issue with it to date.
Ferocity02's Avatar
I have the AEM unit now and I love it. Hasn't given me a single issue and it's nice because it can display lambda instead of AFR, and it can output lambda vs. voltage on 0-5V. You can also adjust the output voltage scale and even use it as a narrowband. Only downside I've seen is that it's a little too bright at night. It autodims so there is no way to adjust it.
Old 07-09-2013, 05:02 PM
Blackpanther99's Avatar
AEM ftw! Cant get any more simple than that.
Old 07-09-2013, 07:24 PM
kelsey_canard's Avatar
My lc1 has started acting up, and is doing the same thing. Its been fine for about a year until I moved it for my turbo. Did you ever find a remedy for this problem?
Old 07-09-2013, 07:32 PM
badboy956's Avatar
Great and i just got mye lc1 yesterday lol hope i dont run into all these problems....Got it mostly because it was blue and it would match the other gauges jajaja
Old 07-09-2013, 07:46 PM
11 sec. Truck Mod
TIM Z's Avatar
X10 I don't like my LC-1 . Works for while then flashes 7.4 till I key off . What a piece of **** .
Had an AEM on my first turbo truck with no probs . Prob am going to **** can my innovate and get another AEM , wish I had my money back
Old 07-09-2013, 07:50 PM
04SilverCrew's Avatar
I have had good luck with the innovate MTX-L wideband. Just the initial calibration and says once a year(I think) to recalibrate for boosted applications. Has inputs/outputs for logging too.
Old 07-09-2013, 09:10 PM
Mod with training wheels
smokeshow's Avatar
Had two LC1s die on me within a week of each other.
Quick Reply: Lc-1 wideband haters
