Lep stage 1 Blower cam
Old 03-10-2012, 10:09 AM
Blacksrt403's Avatar
Looks like I'm gonna be a guinea pig by getting this cam, I was told by garth I would loose 1 to 1.5 psi but gain it from the cam itself.
Old 03-10-2012, 10:59 AM
03sierraslt's Avatar
I would run it, you will loose boost thats for sure. You would most likely be better off with something a bit milder given your setup. All of course just my opinion.
Old 03-10-2012, 11:40 AM
old motorhead's Avatar
I agree. It'll be kick *** when you upgrade to a TVS2300 though
Edit: You might also consider the potential for rotor knock using that cam with an MP112.
Old 03-10-2012, 09:53 PM
I never thought it would be so hard to pick a cam.you go big u loose boost, too small and ur not 100 % happy. Geez
Old 03-10-2012, 10:54 PM
jrmchevyman's Avatar
Try picking a cam in between say a gt2-3 and the Lep stage 1 blower cam?
Get someone to custom spec you a cam and you should be happy. Have you contacted anyone yet like EPS?
Old 03-11-2012, 06:48 AM
Who's eps ?
Old 03-11-2012, 07:59 AM
EPS cut my cam. Well actually comp cut it and EPS spec'ed it.
Old 03-11-2012, 09:39 AM
Get Pat G or Geoff at EPS to spec you a cam. Get one made for your exact setup. Costs little or no more than buying an off the shelf cam. Way cheaper than installing the wrong cam and either living with it or having to go back and do the job again. A 214/226 115lsa EPS cam would work well with your rig. Confirm with one of the experts though..
Old 03-11-2012, 12:09 PM
Motörhead thanks for the advise,that can has a lil lobe too it ?
Old 03-11-2012, 02:52 PM
What does EPs stand for ?
Quick Reply: Lep stage 1 Blower cam
